It is currently Tue Jul 22, 2025 12:04 pm
PostPosted: Sat Feb 10, 2007 3:07 pm
I'm binding my first cedar topped guitar. On previous builds I've glued the binding on with superglue - after sealing the channel with shellac, of course.
So, can I do the same with cedar, or do I need to use a different glue? The cedar seems much softer and absorbent and I just wanted to be sure I don't get any superglue wicking into the top.
PostPosted: Sat Feb 10, 2007 3:20 pm
First name: stan
Last Name: thomison
City: branson
State: mo
Zip/Postal Code: 65616
Country: united states
just did a koa and cedar and like all other binding, did it with ca. don't even seal the channels, but not bad idea if want,just never have had a problem with ca and binding with any wood
PostPosted: Sat Feb 10, 2007 6:37 pm
First name: Danny
Last Name: Vincent
Ditto as with Stan. Just did a sealed cedar top with ca and had no problems.
PostPosted: Sun Feb 11, 2007 12:05 am
Same thing, mahogany/cedar OM, sealed the channel with shellac and used bocote bindings with CA - no problems.
David White, Toronto
PostPosted: Sun Feb 11, 2007 12:13 am
I bound no 3 with Hot hide glue and it was a charm to use, did'n need to use shellac in the channels.
PostPosted: Sun Feb 11, 2007 12:45 am
Thanks guys!
PostPosted: Sun Feb 11, 2007 1:56 am
The CA viscosity makes a difference here. The Stew-Mac thin and medium have worked well for me, but I have witnessed another brand wicking in vigorously - even into denser spruces like Red. It may not be visible until you apply a finish.
Sealing with shellac should do the trick, but still worth a quick experiment or using a little caution. It's no fun to retop a guitar at this point in construction.
Personally, I still prefer Titebond for all my binding. Wicking in CA is an established technique, but I've never warmed up to it.
